10-27-2004 06:34 AM
hi everybody
i have installed ciscoworks snms 1.5 (wug 8, cv 6.0, rme3.5). when accessing ciscoview from the device-center i get a popup-window with message "page cannot be displayed" according to a very strange port following the correct ip-address in the url-string.
invoking cv directly from an icon on a map of whatsup gold works perfectly.
any hints or tips are very much appreciated
thank in advance
roman
11-02-2004 03:10 PM
Guess, it could be due to hostname resolution. Are you using the hostname or the IP address.
For more information :
CISCOWORKS SMALL NETWORK MANAGEMENT SOLUTION
http://www.cisco.com/en/US/products/sw/cscowork/ps2408/index.html
01-29-2005 10:35 AM
This is a bug documented under ID CSCin56485.
Work-around:
1)Remove NMSROOT\MDC\tomcat\webapps\snms\cmic\datastore\uds\records.db
file.
2) Open a command promt.
3) Execute "pdterm Tomcat"
4) Execute "pdexec Apache"
It works.
Attila
