CiscoWorks Syslog Reporting
jrichterkessing
I am running CiscoWorks on a Widows 2003 Enterprise server, my RME version is 4.3.0. The issue I just discovered that when I try running a Syslog report out of RME the history will only go back as far as the last server reboot. For instance, the server is scheduled to reboot every MON at 6:50am....so in running a report today the earliest record is from 6:50am yesterday morning.
To be honest we have been running this on a Windows box for over a year now and I am just now noticing this, but I don't often run reports out of here....so it could have been going on all along.
Is there something I can do to fix this? My purge policy is to purge records older than 14days old, so I don't think that is getting in the way.
Thanks.
Joe Clarke
Check your report parameters.  By default the syslog standard report only looks at the past 24 hours.  Also, if you're getting more than 10,000 messages in a day, you will only see 10K in the on-screen report.
