CiscoWorks trial
Andy White
Participant
Participant
I've downloaded the trial version of CiscoWorks and have installed all the modules.  Does anyone know what the main modules are they use as I'd like to focus on these,  the one I like so far is the CiscoView.  Can't find any pricing for this piece of software anywhere though so I guess it's expensive.
Joe Clarke
The most heavily used modules are Resource Manager Essentials and Campus Manager.  RME gives you inventory, config, software, and syslog management.  Campus provides layer 2 topology, switchport capacity, and end user/IP phone management.
LMS is listed in the price guide, and the price will depend on the number of devices you need to manage.
