01-14-2005 01:58 AM
hello,
some syslog messages arent defined in system and saying "The system reference text for this message is not available. Please use the latest IOS or Catalyst User references for explanation of this message. "
what can I do for this syslogs? is there a way to define them in the system???
thanks
01-14-2005 04:58 AM
Guess you only can install the latest IDU patch(es)
01-17-2005 09:49 AM
perhaps this is what you are looking for...
Login into your management station and search in the online help the words "user url" in the section "Syslog Analysis"
HTH,
Martin
