Ciscoworks with HPOV NNM.
londint
Will Ciscoworks 2.6 run with HPOV NNM 6.31 both windows version?
Also can I install them both on the same box?
In addition, can I install HPOV NNM and
intergrate with Ciscowworks much later?
Joe Clarke
You need at least NNM 6.4 for CiscoWorks integration. While the two apps should coexist without problems provided enough resources, and that CiscoWorks Daemon Manager starts first, you will not be able to integrate LMS and NNM 6.3.
Joe Clarke
