CiscoWorksUserTrackingUtility1.1 not working with Campus 4.0.12
oalvi
After I upgrade Campus Manager to 4.0.12, the CiscoWorksUserTrackingUtility filed to connect as the below message:
(Failed to get user Information from server, Please check if the server is up and the configured user has privileges to access this information)
But I can query via IE portal.
Joe Clarke
How do you have the utility configured?
Thanks Jclarke
The configration of the utiltiy on Pc isn't change.
The problem is solved after rebooting the CaMpus server.
Best regards
