Clear Logs in Cisco Prime 3.4 Syslog Viewer
superego
Beginner
Beginner
Is there a way that we can clear logs in the Prime Syslog Viewer?  If not, how can we reduce the logs/size when viewing the historic or snapshot?
TIA.
juliocarossella
Beginner
Beginner
You can use any of plenty filter options: quick filters, advance filters...
Additionally you can customize filters (advance filters) and save them for futher use. (SYSLOG FILTERS.jpg)
Even though I don´t believe is a good idea, you could probably delete syslog messages from the Administration > Setting > Logging page, shrinking the size and quantity of syslog files. (delete syslog.jpg)
juliocarossella
Beginner
Beginner
Recognize Your Peers
