CLM 3.0 CCO connectivity
enorton66
My installation of CLM worked fine and was able to connect to CCO to interact with the license management service.
Recently, this connectivity is no longer working.  The error I get is Status Code 6007 and states I should check cisco.com account or network connectivity.  I tested the connectivity by executing 'telnet tools9.cisco.com 443' from the server command prompt.  It connected successfully.
I also tested my CCO account successfully, which by the way is the exact same way I am able to connect and post to this community.  What else should I check for to get this working?
david.kelsen
Hi Edwin,
Just curious - did you end up working this out?
I'm experiencing the same problem at the moment.
Dave.
