08-17-2021 05:43 PM
Which is better and is CLM like packet tracer?
08-18-2021 01:52 AM
Hi there,
The important distinction between PacketTracer and GNS3, CML2 and EVE-NG is that PT is a simulator and the others are emulators. The latter group emulate the hardware and run complete software images therefore giving a more representative environment. PT can sometime exhibit some odd behavior which can only be put down to the fact it is a simulator.
Although installing and using PT is the easiest, I would recommended you spend your time setting up an emulator. CML2 is the only one which costs any money, but it does come with a set of platform software images to use. GNS3 and EVE-NG require you to hunt around the internet to find the software.
Personally I would recommend EVE-NG.
cheers,
Seb.
08-18-2021 03:34 PM
What do you study for? I would start with Packet tracer especially at CCNA level before moving to CML, GNS3, Eve. If you study for CCNP/CCIE, then PT is not good and You must use others. Which one to use depends on your resources. They are free ( you can use CML over the DevNet Sandbox free access). GNS3 and Eve require you provide images which you may not have access to. Even if you do, I am not clear on legality of using those images in emulators like GNS3 and Eve.
Regards, ML
**Please Rate All Helpful Responses **
