04-09-2015 07:00 PM
Dear All,
I have a Cisco 2911 router and recently upgraded with IOS : c2900-universalk9-mz.SPA.153-3.M4.bin. The issue is now when every time when I apply "clock timezone xx 8" cli in my router, the command does not reflect. So that my router clock always stays at UTC 0 timezone.
Other CLI is working without problem, only this clock timezone CLI giving weird trouble. and because of this, all the logs timestamps are follow UTC timezone, which will give me problem when doing tracing.
Is there any alternative way to re-activate this command, instead of go back to old IOS.
Thank you.
Reeyon
04-09-2015 07:12 PM
config t
serv time l d s l y
serv time d d s l y
end
04-10-2015 04:34 AM
hi, it is not the timestamp problem. the problem is that whenever I input the command "clock timezone xx 8", is doesn't show in my running-config.
Thank you.
