09-26-2013 08:10 AM
Yesterday I've downloaded and installed the brand new 5.8.8 Network Assitant.
I must say it looks promissing cause it now supports our AP's.
However it seems that it's not showing the topology?
I re-booted, checked my logging, checked JAVA version, Updated JAVA version etc. but so far no luck.
Does anybody have a clue why this happens?
My feeling says it has something to do with JAVA but I still haven't found the root cause.
Any help is more then welcome.
Thanks in advance,
B@rt
Solved! Go to Solution.
10-21-2013 04:24 PM
The 5.8(8.1) patch fixed the issue for me as well.
I notice the release notes don't show it as a resolved caveat. (In fact there are no resolved caveats noted for the past couple releases.)
10-22-2013 12:10 AM
I've installed the latest patch 5.8.8.1 (just released) that is in fact working fine.
My problem is solved.
Best regards,
