178
Highlighted
Beginner
CNA 5.8.9.1 not allowing access to 2960X running 15.0(2)EX4 even though credentials are correct
Hi All,
Are there any known issues with CNA 5.8.9.1 compatibility with a C2960X switch running 15.0(2)EX4?
When I attempt to log in to the switch, I am informed the credentials are invalid although the same credentials work when using the CLI.
Best Regards,
-Evan
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Guru
Have you specified the ip
Have you specified the ip http authentication mode on the switches? CNA uses the http server on the target device.
Test your credentials against the device web interface to verify.
3 REPLIES 3
Highlighted
Hall of Fame Guru
Highlighted
Beginner
This is what was missing on
This is what was missing on the switch. Thank you very much Marvin :)
Highlighted
Hall of Fame Guru
You're welcome - glad it
You're welcome - glad it helped. Thank for the rating.
Content for Community-Ad
