Network Management
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
mo01 by Level 1
  • 84 Views
  • 3 replies
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Sunny5 by Level 1
  • 164 Views
  • 6 replies
I am using the Embedded Packet Capture feature on a C8200L-1N-4T router.I have the capture and need to export it to our TFTP server.When i run the following command:8200_RTR#mon cap DMVPN export tftp://192.168.1.146/Community.pcapI get the following ...
KMNRuser by Level 1
  • 642 Views
  • 8 replies
I'm having problems setting up my home network using Cisco2921 for the first time. It has the basic licenses only. Below is the running config followed by my adapter settings. Any assistance would be greatly appreciated. Thank you.Current configurati...
