collect netflow within same VLAN
jackson.ku
Level 6
Level 6
How can I use the netflow feature of Catalyst 6509 to collect traffic statistics within same VLANs, but the traffic cross to this Catalyst 6509 switch?
Best Regards,
Jackson Ku
Jan Nejman
Level 7
Level 7
on IOS versions you can use the following command:
ip flow export layer2-switched vlan ...
on CatOS is was:
set mls bridged-flow-statistics enable
Bye,
Jan
PS: Please, rate me if I helped you.
