08-22-2013 07:23 AM
I am trying to configure template for collecting traffic statistics through PI.
As per the steps in the Cisco PI document, I tried configuring the new Template, but I am not able to edit the "Form View", not able to fill any row in the "Form View" such as Flow Export Name, IP address, interface etc..
But I am able to save as a new template and publish it.
Please suggest the correct procedure and what might be the possible reason for not able to edit the Form View
Please help
08-22-2013 10:12 AM
Please Help!
08-24-2013 08:17 AM
Could you share which device you want to get traffic statistics??
08-25-2013 10:13 PM
I want to configure on the below list of devices.
Cisco 3850 switches
Cisco Wireless LAN Controller
Cisco 3845 Routers
Cisco 4500X Switch
Cisco ISE
08-26-2013 09:21 PM
Go to Deployment->configuration task.
Using "Medianet - PerfMon" or "Collecting Traffic Statistics" to deployment configuration to SWs.
Please note that this procedure will change configuration of SWs.
So maybe the template command will be not correct with some devices (depend on the model).
So you need to "show run" on SWs to check the configuration are apllied or not.
If you cannot you template, you should change configuration on SWs manually.
Best Regards
