Common Service 3.3 discovery settings not accessible
Muhammed Safwan
Whenever I am clicking on common service 3.3 discovery settings, I am getting http status 500 error.Attached the stdout.log and stderr.log.Please help me to resolve this issue.
Safwan
Try this system-config.xml.
14 Replies 14
Joe Clarke
It looks as though your discovery settings are corrupt.  Post the NMSROOT/etc/csdiscovery/CSDiscovery-config.xml file.
Hi Joe,
Thanks for your reply.Attached the CSDiscovery-config.xml file.
Safwan
Replace your config file with this version.  It should correct the problem.
Hi Joe ,
I have replaced the config file,but still same problem.Please help.
Safwan
Try this one instead.
Hi Joe,
I have tried with second version also,but still same problem.
Safwan
I see no other problems with the config file.  Try restarting Daemon Manager, and see if the error persists.
Dameon service restatred and machine is also restarted but still the discovery setting page is giving the same error.
safwan
Post he output of the DOS command "DIR C:\PROGRA~1\CSCOpx\conf\csdiscovery".
hi joe,
Please find the attachment for the requested output.
safwan
The file size does not agree with what I sent you.  Post the current CSDiscovery-config.xml and the system-config.xml.
Hi Joe,
Please find the latest config files.
Safwan
Hi Joe,
It worked perfectly,thanks for you very much for excellent solution.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
