Communication failure between the SM and the SCE
i have upgard SM from 3.1.0 to 3.1.5 and after that the SCE can't sync to SM any one has work around on this issue.
SM Version: 3.1.5 Build 25 use pqi SCABB 3.1.5 build 25
SCE Version 3.1.5 Build 263
QS-2020#sh system operation-status
System Operation status is Warning
Description:
1. Lost connection with Subscriber Manager
[pcube@qs2020-sm bin]$ ./p3sm --resync-all
Error - Failed to synchronize all boxes
SCE QS-2020 had errors during subscribers synchronization: failed to synchronize 2 subscribers
[pcube@qs2020-sm bin]$ ./p3sm --sm-status
SM is running.
SM operational state is Active
Command terminated successfully
smalkeric
Level 6
Level 6
SM failed to become Active because when a failover is initiated, there is a so-called "make-active timeout"
that is watched during the failover process, to make the failover process doesn't take indefinitely. This timeout is 40 seconds.
If the Radius Server is on the SCE subscriber side, the second accounting request on a new flow (new tuple) will end up with the SCE sends corrupted RDRs.
And also removes the anonymous-group from the SCE configuration.
