Compliance Check/Deploy DCMA0058 error
lanwancig1
Beginner
Beginner
Using LMS 3.2 RME 4.3.0. I'm trying to deploy baseline config after compliance check. When I select compliance check job and click deploy i got this error:
"DCMA0058: Could not deploy selected Job.
No compliance report available."
But the report in baseline jobs window i available.
Any ideas what should i check ??
Nael Mohammad
Contributor
Contributor
Please run a device update from Common Services --> Software Center --> Device Update --> Select RME under products and check for updates from Cisco.com and install all the device packages.
Duplicate the problem again after update and post the error if it appears again.
Nael Mohammad
Contributor
Contributor
Thanks a lot. Seams to work for me.
Recognize Your Peers
