I have upgraded cisco NCS-5504 router . Router was successfully upgraded but all the line cards are not showing. In platform command type is unknown and state is SW_Inactive.Regards Salman
The content you are looking for has been archived. View related content below.
Having tried to register the MAC address on the website, the LED on the device is still flashing blue.
Hello,i have a pc connected to VPC Peer Switch (vPC2) which has the secondary role. vPC2 builts a vPC with vPC1. How can i configure the port to always keep up the connection for this device, even when peer-link goes down (dragging out the cables).In...
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
I cannot edit or duplicate template is Prime Infrastructure anymore.It started many month ago with Chrome.My Workaround was to use Firefox.But with the Update to Firefox 125 the same Issue is now happening here.I guess Chrome and Firefox disabled som...
I want to create an ACL on Cisco to prevent one network from communicating with others except for the internet. Can you help?
Hello. I can't log on CSLU using cisco account, but I can log on other cisco web sites using same credentials. (license, download... etc) I also can pass test connection in CSLU. The strange thing is I can log on CSLU using my private cisco account. ...
Hello, Je désire resetter le mot de passe d'un Switch Cisco Cisco N3K(C-31108TC-V). Je n'Ai pas accès au CLI via ssh ou console port. Merci pour vos retours
At my new job, I was told RADIUS hasn't functioned for over a year. I wiped the RADIUS server settings and started from scratch. I'm happy to say, after going thru every cisco device, ALMOST all devices now login via RADIUS flawlessly. There are t...
Hello,Does anyone know if there is a way to log bgp routes updates? Obviously there is a way to see adjacencies changes, but I am needing to see route updates by logging so I can send the output to a Syslog server?CheersSteven
Helo SIRplease help me, I want to add a temperature switch graph to the cacti, how do I do it? how many OIDs do I need to add to the cacti? I use Cisco WS-C2960L-48TS-LL and C9300-48T-4X-E switches, thank you
Hi We are configuring cisco devices via python. and also trying to exploring with API. When using API, there are some connection issues which are not clear yet. So I would like to know what kinds of cisco device can support API. and how can we use AP...
Hi Everyone I am enabling netconf on Cat9k switches and want to use a custom AAA group for it and not just the default. I have the following configuration that works, but want to change it so we use a named group and not the default: aaa new-model ! ...
Hi All!I am currently deploying NAC in my organisation's switches and was wondering if there is a Python script to help ease this task.The commands are almost the same on all the ports, except for the dot1x/mab priority one when there's a device conn...
Subject | Author | Posted |
04-23-2024 12:20 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM | ||
04-13-2024 12:00 PM | ||
04-11-2024 05:18 AM |
User | Count |
4 | |
2 | |
1 | |
1 | |
1 |
