Configuration Archive on Cisco Prime Infrastructure 3.0
Abbas Ravat
Dear Friend
Recently I have installed Cisco Prime Infrastructure 3.0 for one of our customer. I add the devices and now I did configuration archive for some devices to backup the configuration. kindly please tell, cisco prime infrastructure 3.0 by default were does it save this configuration archive of the devices and how can I access it.
Abbas M. Ravat
Marvin Rhoads
Prime Infrastructure stores the backups as records in its Oracle database. The supported method for seeing them is via the GUI.
Look under Inventory > Configuration Archive for the individual devices and you will see several options for seeing the configurations of a given device (raw, processed, compare two configs, etc.).
There is a method for extracting all of the configuration files into a zipped file but it involves querying the Oracle database from the cli and is not recommended for the non-expert or casual user.
