02-09-2021 04:43 PM
I configured the access point as standalone but I cannot access it through the browser.
Solved! Go to Solution.
02-09-2021 05:54 PM
use the following code to change the IP address of the AP:
interface BVI1
ip address 172.16.10.100 255.255.255.0
no ipv6 enable
ip route 0.0.0.0 0.0.0.0 172.16.10.1Enable the web interface with the following commands
ip http server
ip http secure-server
ip http authentication localThe switch is going to prompt you for credentials to login so we create those with the following command:
username MYNAME priv 15 secret MySuperS3cretP@55wordNow you should be able to put http://172.16.10.100 into a web browser and get to the web interface.
02-09-2021 04:44 PM
# ap: delete flash:private-config
# ap: delete flash:private-multiple-fs
# ap: set IP_ADDR 172.16.10.100
# ap: set NETMASK 255.255.255.0
# ap: set DEFAULT_ROUTER 172.16.10.12
# ap: tftp_init
# ap: ether_init
# ap: flash_init
# ap: tar -xtract tftp://172.16.10.12/c1140-k9w7-tar.153-3.JPK.tar flash:
# ap: set BOOT flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-mx.153-3.JPK
# ap: set make sure BOOT=flash:/c1140-k9w7-tar.153-3.JPK/c1140-k9w7-tar.153-3.JPK
# ap: boot
02-09-2021 05:02 PM
The configuration you show above is all the commands you entered in ROMMON but the IP address does not carry into the IOS. Can you post the output of a "show run"?
02-09-2021 05:16 PM
pc-244-254-160-190#show run
Building configuration...
Current configuration : 1995 bytes
version 15.3
no service pad
service password-encryption
hostname pc-244-254-160-190
logging rate-limit console 9
enable secret 5 $1$4.K3$fLNXCs.FdLxrq5uIr2owO0
no aaa new-model
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 ssid SSID-NAME
vlan 254
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 06575D72181B5F4E5D
no ipv6 cef
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
shutdown
encryption mode ciphers aes-ccm
encryption vlan 254 mode ciphers aes-ccm
ssid SSID-NAME
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
peakdetect
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface BVI1
mac-address 843d.c66e.eac4
ip address 190.160.254.2 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
en
02-09-2021 05:54 PM
interface BVI1
no ipv6 enable
ip http server
02-09-2021 07:09 PM
it works, thank you so much
