configure ip flow destinatio to a DNS record
yoav-shneor
Hi ,
Is it possible to configure ip flow destination to a DNS record ?
insted of writing an ip address , to insert a name like "myflow.customer.org" .
Is it possible ?
do i need to config resolving ? or local host for that ?
marce1000
 - Put a ? at the end of the designated command, you will see what the possible options are for the host name , probably it can be a DNS name , which must then be resolvable at the time the command is being entered BUT what happens is that the translated address is burned into the running config , meaning that the 'DNS gaming' can not be used for failover purposes,
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
marce1000
 M.
TNX Bro ,
