Dear Friends,
I am in process of configuring hsrp using dynamips
when i am putting the comand
SW1(config)#standby 1 ip 10.1.1.10
% Invalid input detected at '^' marker.
its showing error i,e the command is support by switch ios
Please check the show version command for ios details
"SW1#sh version Cisco IOS Software, 3600 Software (C3640-IK9O3S-M), Version 12.4(7), RELEASE SOF TWARE (fc6) Technical Support: http://www.cisco.com/techsupportCopyright (c) 1986-2006 by Cisco Systems, Inc. Compiled Wed 01-Mar-06 00:58 by alnguyen ROM: ROMMON Emulation Microcode ROM: 3600 Software (C3640-IK9O3S-M), Version 12.4(7), RELEASE SOFTWARE (fc6) SW1 uptime is 3 hours, 13 minutes System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0 x0, BOOT_COUNT 0, BOOTDATA 19 System image file is "tftp://255.255.255.255/unknown" Cisco 3640 (R4700) processor (revision 0xFF) with 94208K/4096K bytes of memory. Processor board ID 00000000 R4700 CPU at 100MHz, Implementation 33, Rev 1.2 16 FastEthernet interfaces DRAM configuration is 64 bits wide with parity enabled. 125K bytes of NVRAM. 8192K bytes of processor board System flash (Read/Write) Configuration register is 0x2102 "
Can anyone help me in solving this issue. Any kind of help is greatly appreciated
