344
Beginner
Configuring Multiple Switches Simultaneously
Hello Community,
i have to role out some config parameters to exsisting switches in total 200. All config parameters are the same for the switches.
What is the best way to confiure the switches simultaneously, without configuring one-by-one?
Are there any best practices out there?
Kind Regards
Patrick
6 REPLIES 6
Highlighted
Participant
Re: Configuring Multiple Switches Simultaneously
There are a lot of ways to accomplish this, depending on the tools you have on-hand.  This does require an automation platform. This can be something you already have for monitoring, i.e. Cisco Prime LAN Management, Solarwinds NCM, KiwiKat Tools, DNA-C, or other....  If you don't, you can look Ansible.  Really being able to make Ansible do complex tasks does require some programming and scripting understanding.  What do you uses today for graphical network management, reporting, and alerting?
-Pete
Beginner
Hello Pete,
at the moment there is no Graphical Network Management, Ansible will come in the future but not at the moment. We want to try it without Ansible. Does appliacation like SecureCRT, Putty can acomblish that requirement?
Kind Regards
Patrick
Participant
Let me know if this is what you are looking for:
https://www.vandyke.com/support/tips/chatsendcom.html
Beginner
Thanks thats helpful at the moment, i will try that.
Many Thanks
Patrick
Participant
How'd it work out for you Patrick?
Cheers,
Pete
Beginner
It worked very well, thanks.
kind regards
Patrick
Content for Community-Ad
July's Community Spotlight Awards
