01-13-2011 02:46 PM
I have a WS-C3560X-24P with this SW version 12.2(55)SE1. It has several L3 Vlan interfaces.
How do I enable it to send Netflow traps?
It does not support the ip flow-export commands.
thanks!!!
Sergio
01-14-2011 02:00 AM
3560 series doesn't support netflow. There are only two sulutions:
1. use another switch 4500 or 6500 -> more expensive solution
2. try use a netflow probe. There are commercial sulutions and
free solutions. The probe is connected via span/mirror port or
via optical tap/splitter.
Visit http://support.caligare.com/kb/entry/42/ to see a list of
supported devices.
I'm sorry, both solutions are not ideal, but what is in the world?
Jan
PS.: Please, rate if you are satisfied.
01-14-2011 06:33 AM
Thanks Jan!
03-22-2012 03:24 PM
OR you could purchase the C3KX-SM-10G expansion module to enable Netflow Support. It costs around $2,300.
