any news about full support of Cisco Catalyst 3560 and C6800?
C6800 can be managed but there is no info about device, soft, interfaces...
C3560 can be managed but get "collection failure" and there is no data available for interfaces.
pi_update_2.0-3.ubf and pi_dev_pack_update_2.0-13.ubf has been loaded.
Thanks in advance.
Solved! Go to Solution.
WS-C3650-48PD
Your thread says "3560". This model is supported with PI 2.0.
But your "sh version" shows your switch to be a "3650". Two different models but because the 3650 is a newer model, it's not yet supported by PI2.0.
Not sure if 3650 and 6800 will be supported when CPI 2.1 get release.
Hence I wanted to ask for the show version. As 3560 is a switch, but 3650 is released just a few weeks agao.
Though the NGWC devices are planned to get supported pretty faster in PI, this device will be supported on PI 2.0.1 and 2.1 onwards.
I guess the releases are suppose to come out shortly.
So, both of you devices in question are not supported for now. Please wait a little for next release to come.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
c6800 doesn't shows on the suppported devices list of PI 2.0. However 3560's are. Such "Collection failure" messages are being seen with corrupt DB for device data.
Can you please try to delete and re-add the device once again.
You can download the PI 2.0 supported device from here :
-Thanks
Vinod
**Encourage contributors. RATE them. **
Hello Vinod,
I have deleted device and re-added after, but I get same issue.
Any other idea about it?
Here we have log:
[ICE Service[ 1]Thread: 31] [ice] [ERROR] - An error occurred while processing post-collection hook: 192.168.1.1 for device with id 2453454 java.lang.reflect.InvocationTargetException with cause com.cisco.xmp.inventory.ice.PostCollectionHookException:
Thanks!
As per the error it says :
Wireless Controller inventory collection failed
Please confirm if this is a switch of any Wireless controller? Share show version from the device.
Logs should be available on Inventory.log.
-Thanks
Vinod
Is a switch with wireless controller capabilities.
Switch#sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.00SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 02-Oct-13 21:51 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3650-48PD (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO1752Q08R
4 Virtual Ethernet interfaces
128 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
250456K bytes of Crash Files at crashinfo-3:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
1609272K bytes of Flash at flash-3:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of Dummy USB Flash at usbflash0-3:.
0K bytes of at webui:.
Base Ethernet MAC Address : b8:38:80:6a:80:80
Motherboard Assembly Number : 73-15125-05
Motherboard Serial Number : BBBBBBBB
Model Revision Number : A0
Motherboard Revision Number : A0
Model Number : WS-C3650-48PD
System Serial Number : FDO1752Q08R
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PD 03.03.00SE cat3k_caa-universalk9 INSTALL
2 52 WS-C3650-48PS 03.03.00SE cat3k_caa-universalk9 INSTALL
3 28 WS-C3650-24PD 03.03.00SE cat3k_caa-universalk9 INSTALL
Thanks!
WS-C3650-48PD
-Thanks
Vinod
Thanks for you info Leo & Vinod and sorry about mistake on model of catalyst.
I hope new CPI relase comes out soon.
Regards.
Cisco is aware of new controller in NGWC needs to be managed via PI. The new releases are planned as early as possible in Mar-Apr.
-Thanks
Vinod
**Encourage Contributors. RATE them. **
Thanks for taking the time to rate our posts.
