CPI 3.1 - Management VLAN IP
josrankin
In CPI, is there a way to change the IP address associated with a core switch that has multiple VLAN interfaces configured? When I discover a switch with multiple VLAN interfaces, it always comes back with the highest IP address. I need the address to be the management VLAN address instead, which is a lower VLAN number and IP. Is there a workaround for this? Thanks.
Marvin Rhoads
You can just add the switch manually vs via autodiscovery.
I figured out a way to do it. I used a ping sweep to find only that VLAN and selected "None" under Preferred Management IP. The discovery came back with the desired address.
