CPU Hog and reclaim ports
georgeef1
Beginner
Beginner
I am having an issue with several switches being polled via SNMP by LMS.
They become unresponsive (as reported by Device Fault Manager alerts) and turn red on the
map. The log on the individual devices has this :
Mar 24 08:32:22: cfg_bridgePlatformNextTpFdbEntry: Error, forced exit of an infinite loop
on MAC Address 0100.5e00.00fb
Mar 24 08:32:22: %SYS-3-CPUHOG: Task ran for 10156 msec (26970/22), process = IP SNMP, PC
= 801D1C9C.
-Traceback= 801D1CA4 80076610
I am also having an issue with LMS being unable to generate a report on reclaiming unused
access ports. It always displays the message "Report not available - No Reclaim Unused
Up/Down ports found." despite the fact that there are unused ports on the switch.
Please check,
Thanks.
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
I will address the CPUHOG issue in this thread. Start a new thread for your Campus issue.
What is the IOS image running on the device that generated this stack trace?
Recognize Your Peers
