Create dfm group based on interface descriptions
Jdullerud_2
Hi.
Can someone please tell me how to make an user defined group that lists all the interfaces in the routers in the dfm db based on matches in the desc field on the int. example: int f0/0; Description :lan:ntp:north:
If this descr is used on 20 int onn 20 diff routers i want them in a group called ntp_north.
I have tried some of the variables but my new group won't be popolated with interfaces, i only get routers witch the interfaces belongs to, this is only when I use the interface.type and contains e.g. ether.
/jon magnus
s-doyle
Level 3
Level 3
Refer to the section 'Working with Customizable Groups' of the DFM user guide.
http://www.cisco.com/en/US/products/sw/cscowork/ps2421/products_user_guide_chapter09186a00804fc528.html#wp1059743
