CS > admin >Resource Browser
michaelatef
Hi guys ;
In LMS 2.5.1 in
CS > admin >Resource Browser:
+ what is the function of resource browser?
+ what resources to free up ??
+ why it is always empty !!
thanks in advance
miheg
Level 5
Level 5
I may show config files that are "checked out". This means someone is editing a device config and nobody else can touch the config at that time, unless they first free the resource.
Cheers,
Michel
hi miheg;
thanks for ur reply ,but i tried to do what u said but it was still empty !!!
thanks
Its fine for it to be empty, it means there is nothing currently checked out. With this page you can view and sort resources, and free locked resources, using this option, if you have appropriate privileges.
If you go to another application such as netconfig and it gives an error message that a resource is checked out, you could then go to this page to see what it is.
how are you trying to test this piece of the app?
