05-21-2007 03:50 PM
Just wondering if its at all posible to access IPM statistical data for the creation of our own personalised graphs and reports?
Solved! Go to Solution.
05-21-2007 04:04 PM
Sure. With IPM we publish the database schema. While you won't get TAC support for custom applications, you can certainly access the database to get what you need.
You should be able to find the schema in the docs subdirectory on the IPM CD-ROM.
05-21-2007 04:04 PM
