Custom Report Question - Finding GBICs
simon.bell
I've been trying to build a custom report that shows the information contained in "Detailed Device Report" > Processor Port Interfaces > Port Description
This shows which port has what type of GBIC installed, but I cannot find an attribute in the Custom Report Generator that reports this information.
Can anyone offer some guidance?
TIA
6 Replies 6
Joe Clarke
What version of RME?
4.2.0 - Windows Host
This table seems to still be a casualty of CSCsj78780, a feature request asking for more attributes to be available for custom reports. Until this is added, you can export the DDR, and extract the data from there.
Dang... get'n the data from the DDR is how i'm currently doing it, it's just a bit of a pain... thanks tho.
simon
so in the bugID it say's it was resolved in 4.1.1 - is this still an open issue dev is working on?
Yes. The bug is currently Postponed pending resolution of more missing elements. The true fix for this may only come in the new ODBC access being provided in LMS 3.2. While the initial phase will not export this data, and future release will most likely make it available.
