Customize Job Approval Emails
simon.bell
We're wanting to integrate the job approval emails with Remedy, however, Remedy is very restrictive on the formatting. Is there a way (hack?) to modify how the emails are formatted via a config file or some other means?
Just thought I'd ask.
TIA
Joe Clarke
This is not possible. The format is set within the code. However, you could send the email to an intermediary, and have it reformat it for Remedy.
I was afraid you were gonna say that...
