CW2000 and MPLS-Network-View without CDP
mfilser
Hi all.
I've installed a CW2K-System and the discovery was successful. But there ist one thing, that's not so fine.
The locations of the customer are connected via MPLS.
Between the routers is CDP disabled. Now, there is no link between the locations in CM3.3 - but this is normal, because cdp is missing for the CM.
Is there any other possibility, to display a link without a cdp-information. Or is it possible, to create something like a "static cdp connection" on a router?
Thanks for your brainstorming
Markus
rmushtaq
Level 8
Level 8
If cdp is disabled, then you'll have to add these devices as individual seed for discovery.
