I think a have this bug. I done the workaround but I can't fix the error at all.
bug : CSCsj94584:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsj94584
follow the workaround carefully:
1. Modify the .info files for the patched modules under NMSROOT/setup and
set the value of PATCHVER in these files to their original value of 0.
cmf.info
cvw1.info
nmim.info
cdone.info
rme.info
cwa.info
portl.info
2. Install the new application on CiscoWorks Server.
3. Reset the values of PATCHVER to their original patched versions after the installation is complete.
I do the 3 steps, I modified all this files , but the file "nmim.infoâ doesen't exist.
Now when I put the installation DVD , this situation improved, only get the error with the CiscoView module.
Pleaseeee, can tell me whats wrong?
best regards!
