CWLMS 3.2 Win2008 Datacenter R2 64 bit
vergeerf
Beginner
Beginner
Is  Windows 2008 R2 Datacenter (64 bits) supported for CWLMS 3.2, the url below doesn't specifically talk 'bout the datacenter release. Will it work and do we have TAC support?
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1099303
JAMES SEGAL
Beginner
Beginner
I was not able to install it under Win 2K8 DC R2 x64.  The installer starts, but then errors out and says "The OS is not supported.  Please install on a supported OS" (or something like that).  I had to rebuild the server with Win 2K3 R2 Standard Edition....
Recognize Your Peers
