rgomes
Beginner
Daemon manager lms 3.2 starts and dies
After running OK during several months the lms3.2 daemon manager is going down without starting the lms services.
I have already run resetcasuser and did not helped.
I found that the casusers group had not the proper permissions on the cmd.exe file, I had this problem on an CUOM 2.3 installation, but
even after correcting the cmd.exe permissions the error persists.
I am posting the dmgtd related lines extracted from the syslog.log.
Any help is appreciated.
7 REPLIES 7
AFROJ AHMAD
Hi ,
1.-Please check that the IIS service is not running on the server. (If running stop and disable it) 2.-Please try by adding the casuser to the administrator group : From My computer click the right button of the mouse and select Manage. Go to local users, double click on casuser and select tab 'Member of' Add to 'Administrator'
Then :
Go to CSCOpx\setup\support in DOS prompt. Run the command 'resetcasuser' provide a password according to the password policies.
Now try to restart: c:\>net stop crmdmgtd (wait for a couple of minutes after each command) c:\>net start crmdmgtd (wait full 5 minutes and then log in Cisco works) I hope this should work !!
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Reseting casuser after putting casuser under the Administrator group did not solved the problem.
As a desperate try the customer started all daemons manually, he could log in but got license errors.
See the atached files.
Hi ,
Go to services.msc > change the Daemon Manager status from AUTOMATIC to MANUAL .
Reboot the server
once the server is back , changed the status back to Automatic and then try to start the Daemon Manager (net start crmdmgtd)
Is your server runnning under Domain ?
what is the Opearting system on the servre ?
Is LMS integarted with ACS ?
Thanks--
Afroj
Done the procedure described by Afroj, however, no success.
System: Microsoft Windows Server 2003
Enterprise x64 Edition
Service Pack 2
The server is the domain and is not integrated with the Cisco ACS.
Daniel Moreira.
Hi Daniel ,
Is it possible to remove the server from Domain just for testing..?
Remove the server from Domain and then try to start the daemon manager..
Thanks--
Afroj
Hi Afroj,
Sorry, actually is the CiscoWorks is integrated with the Cisco ACS.
Does that change anything?
Daniel Moreira
Hi Daniel,
As the Daemon Manager is  not getting start .
Can you Break the LMS and ACS Integration as below :
on the Command prompt :
NMSROOT\bin >perl ResetLoginModule.pl
and now tried to start the Daemon Manager..
Also did you treid to remove the server from Domain and then tried to start the Daemons ?
Afroj
