12-13-2017 05:40 AM - edited 03-01-2019 06:18 PM
I have a clean VM installation of DCNM 10.4.1 and cannot get the e-mail forwarding working.
We use a exchange mail server and whitelisted the IP address of DCNM.
Using the test function we don't receive any e-mail and also no message on DCNM.
Is this a bug?
Solved! Go to Solution.
02-27-2018 02:12 AM
I tried to send the e-mail to a laptop with Wireshark, but no attempt for DSCM to send a "test" mail.
Eventually I was successful by changing the default DSCN config and used syslog messages up to info level.
As a test I picked a common syslog message and added that as e-mail forwarder action and finally I say that DCNM was sending a e-mail. However the test button still did not work..
Eventually I opened a TAC case for this and god an answer,
It seems that the test button is only for SAN devices, you will get a dropdown box to select your SAN device. Since I only have two LAN devices this button never showed anything letting me believe it was a simple test button to test the e-mail function..
Also for LAN device you can’t use the SNMP TRAP forwarding only syslog is supported for LAN devices.
Sometimes I fail to see the logic on Cisco products…
12-13-2017 09:09 AM
- Check the designated SMTP server's logfile (too) and see wether there is any connection attempt from the DCNM server.
M.
02-27-2018 02:12 AM
