DCNM 5.2(2c) - Discrepancy in device accounting log
MathieuJM_2
I have installed DCNM 5.2(2c) on windows box to manage Nexus 7K devices.
I have for the time being one device that i have manage and i see often the following text:
Discrepancy in device accounting log,Recommended action: clear the accounting log and discover the device. Device details are not available.
How can i delete the accounting log and why do i have this message ?
Cheers
MathieuJM_2
No one has the same issue ?
Cheers
I've the same issue with 4 5596UP.
Cheers
Do you have a fix for this? Would ypou mind sharing the fix?
jeremyp81
Go to the VDC you are discovering and input the following:-
"clear accounting log"
Re-discover the device in DCNM and it should be successful.
