Beginner
DCNM 6.2.1/ DCNM_LAN I have not device management
According to Cisco documentation in paragraph (DCNM Server Administration -> Devices and Credentials) It has equipment management, you can add, delete, etc.. But in my case I have none of these options I can only change the username and password.
The problem is that not find all vdc’s, and those who find it does with ip's that the program randomly choose and security policies are not enabled in the firewall for these ip’s
Also, in the Web Client with management ip's that was defined in Nexus, find the all vdc but only one gets the Managed status. The others vdc, remain with the Enable Deep Discovery in Edit Dialog status. In principle this is active when using SNMPv3.
You know that this can happen or someone have the same problem?
Can you help me?
Everyone's tags (5)
Content for Community-Ad
