07-22-2015 03:24 AM
Hello, I upgraded from DCNM 7.1.2 to DCNM 7.2.1, windows 64bit, the process was "automatic" ( old version was recognized by new DCNM) and everything seems fine except that the web interface is no longer available....before upgrading it was working...
On the server.properties file, the designated port is 80 ( web.port=80), like it was before, but I'm getting error 404.
Rebooted the server, no luck.
I tried to change it ( web.port=8081 ) and restarted the Cisco DCNM SAN Server service, but no luck. ( I use DCNM in order to monitor SAN ).
The Java ( provisioning) part is working fine tho....
Any suggestion ? I cannot access anymore the historical performance data, nor I don't even know if DCNM is still collecting data from the MDS sources...
Thank you in advance.
Andrea
07-22-2015 08:26 AM
Hi Andrea,
The DCNM server is most likely operating fine except for delivering the web page. You can verify if DCNM is still polling devices by logging into a switch and running the command 'show users.' The user account used by DCNM should be logged in.
-Eric
07-23-2015 01:48 AM
Eric thank you, I accessed the JBoss admin console and...well, I don't know really what I did, I'm pretty sure I just browsed through the web setup, and the web interface is now working again.
Really, I'm puzzled....I was stuck for about 3/4 hours before I decide to log into the console and try to see what was happening....
Thank you for the info anyway !
Ciao Andrea
