DCNM Web Interface. Not enough Access
SOcchiogrosso
Level 4
Level 4
When I log into the DCNM Web interface, and click on 'Admin -> Data Sources' I get prompted with a window stating 'User does not have enough righ for the page'
I've got DCNM authenticating via ACS v5.3 & I've created the shell profile for the AV-Pair. Also when I view the ACS logs I see the proper authorization profile getting assigned.
Screen shots attached. Any thoughts?
CCNP, CCIP, CCDP, CCNA: Security/Wireless
Blog: http://ccie-or-null.net/
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
jasoncgross
It took a lot of trial and error, but I eventually found that this works -- I'm using DCNM version 6.2(5):
Attribute:  cisco-av-pair
Requirement:  Mandatory
Attribute Value:  Static
Value:  shell:roles="network-admin"
...although if you want a non-admin or DCNM "User" role, you would use the following instead:
Value: shell:roles="network-operator"
Here's a useful link for more info:  http://www.cisco.com/en/US/products/ps9911/products_configuration_example09186a0080bf5512.shtml
