DCRServer Fails to Load Properly on LMS4.0.1
Mick O'Donovan
We are running an instance of LMS4.0.1 on a Windows 2008 Server installation that is managing circa 2k devices. A couple of weeks ago we run into disk usage problems as a result of log files not being rotated properly - this issue has been fully resolved.
Since then, we have been unable to restart our DCRServer and this is becoming a real issue for us.
The output of a pshow DCRServer is below ...
C:\Users\modonovan>pdshow DCRServer
        Process= DCRServer
        State  = Waiting to initialize.
        Pid    = 8964
        RC     = 0
        Signo  = 0
        Start  = 2/18/2013 2:54:31 PM
        Stop   = Not applicable
        Core   = Not applicable
        Info   = Server started by admin request
Continuously the State will be "Waiting to initialize". Several restarts of the daemon and the server itself have made no difference. I would appreciate any help that we can get it solving this issue as it's most frustrating.
Here's the full output of the pdshow and DCRServer.log attached if it helps.
Thanks in advance,
Mick
AFROJ AHMAD
Hi ,
Send me the screenshot of the SERVICES.MSC .
Also share me the ctm_confix.txt file (locations: NMSROOT\CSCOpx\MDC\tomcat\shared\lib) and
NMSROOT\CSCOpx\MDC\tomcat\webapps\cwhp\WEB-INF\lib
Also try to reset teh Casuser as below and see how it works
NMSROOT\CSCOpc\set\support>resetCasuser.exe
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
