168
Highlighted
Beginner
Detect an out of standard IOS level on device with EEM in order to keep devices on standard IOS?
Can EEM detect the IOS version of a device, compare it to a user defined value, and send a trap if the device's IOS version does not match the standard?
Everyone's tags (1)
3 REPLIES 3
VIP Advisor
You could, but boy what a lot
You could, but boy what a lot of work that would be - and I don't think it would be a good solution.
You are far better to use an SNMP tool to collect the information and then report on it.
VIP Mentor
Cisco Prime can do that for
Cisco Prime can do that for you under the PSIRT reporting tool from 3.0 and up and also check for vulnerabilities in the versions you have
Hall of Fame Cisco Employee
As Philip said, yes, EEM can
As Philip said, yes, EEM can do it.  The applet policy wouldn't be that complicated, either.  The trouble will be you'd need to deploy this on all your devices.  And if you had a config management tool already, chances are you have an inventory manager that could report on this across all of your devices.
Content for Community-Ad
July's Community Spotlight Awards
