Device attributes
paltel
How we can solve the TACACS attribute error "not supported" at the RME Inventory check device attributes?
Thanks in advance
7 Replies 7
nhabib
Level 9
Level 9
Are you using SSH? Does this happen for all devices?
thanks for your reply... telnet.
I noticed that this happens to 1841 routers only.
Go to RME -> Admin -> Inventory -> List Devices
Are the 1841 routers represented with a router icon or SNMP icon?
You are right. SNMP .
I downloaded the packs for updated ones including the Cisco routers 1841. I try to henerate Cisco 1841 routers but i did not see this pack.
Note: the server restarted the services after it completed the required packs.
Go to Server Configuration -> About the Server -> Applications and Versions
There is a section with the heading of Patches Installed. What is listed there?
The list as follows:
Packages Installed
Name Version Install Date Installed Patches State
Inventory Manager 3.4 8-8-2005 15:02:23 none ENABLED
ANI 4.1 8-8-2005 14:24:03 none ENABLED
ANI Device Factory 4.1 8-8-2005 14:24:03 none ENABLED
Configuration Archive Device Support for the IOS 1.3 8-8-2005 15:02:23 none ENABLED
Configuration Archive Device Support for the Catalyst 2.3 8-8-2005 15:02:23 none ENABLED
Configuration Archive Device Support for the FastSwitch 2.3 8-8-2005 15:02:23 none ENABLED
Configuration Archive Device Support for the PIX Firewall 1.3 8-8-2005 15:02:24 none ENABLED
Configuration Archive Device Support for the CSS Switch 1.3 8-8-2005 15:02:24 none ENABLED
Configuration Transport Services 2.2 8-8-2005 15:02:24 none ENABLED
Common Management Foundation 2.1 8-8-2005 14:24:03 none ENABLED
CMF java2 engine 1.2 8-8-2005 14:24:03 none ENABLED
CMF Web Desktop 2.1 8-8-2005 14:24:03 none ENABLED
Configuration Incremental Device Support 1.3 8-8-2005 15:02:24 none ENABLED
Configuration Archive 3.4 8-8-2005 15:02:24 none ENABLED
Contract Connection 3.2 8-8-2005 15:02:24 none ENABLED
CiscoView 5.4 8-8-2005 14:24:03 none ENABLED
Database package 4.1 8-8-2005 14:24:03 none ENABLED
DEE Package 1.0 8-8-2005 15:02:24 none ENABLED
Device Navigator 3.4 8-8-2005 15:02:24 none ENABLED
CW2000 Process Management package 3.4 8-8-2005 14:24:03 none ENABLED
CD One Help 2.1 8-8-2005 14:24:03 none ENABLED
Config Editor 3.4 8-8-2005 15:02:24 none ENABLED
CMF Event Distribution System 3.1 8-8-2005 14:24:03 none ENABLED
Event Services Software 1.0 8-8-2005 14:24:03 none ENABLED
Argent Grid classes 1.29 8-8-2005 14:24:03 none ENABLED
Inventory Device Support for Aironet 1.0 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for the Generic SNMP 1.3 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for the Catalyst 1.5 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for Call Manager 1.3 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for the Router 700 1.3 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for the Workgroup Concentrator 3.4 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for Content Service Switch 1.0 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for the Catalyst 1700 1.3 8-8-2005 15:02:24 none ENABLED
Inventory Device Support for the Catalyst 3900 1.3 8-8-2005 15:02:25 none ENABLED
Inventory Device Support for the Catalyst 2600 1.3 8-8-2005 15:02:25 none ENABLED
Inventory Device Support for the Catalyst 1800 1.3 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for Optical Switch 1.0 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for the Router 3.4 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for the SwitchProbe 1.3 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for the Catalyst 2600 OEM 1.3 8-8-2005 15:02:26 none ENABLED
Inventory Custom Reports 3.4 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for VPN 3000 Concentrator 1.2 8-8-2005 15:02:26 none ENABLED
Inventory Incremental Device Support 3.4 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for the Catalyst KalpanaSwitch 1.3 8-8-2005 15:02:26 none ENABLED
Inventory Device Support for the Catalyst EtherSwitch 1.3 8-8-2005 15:02:26 none ENABLED
Inventory Reports 3.4 8-8-2005 15:02:26 none ENABLED
"I hope that i didn't remove the required sections"
Another thing, before i re-install the Ciscoworks i was able to access it trough the web from any workstation, but now i can only access it locally.
Any idea.
Thanks in advance
Make sure you have installed the latest RME IDU (11.0 I believe):
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme
If that doesn't fix the problem, you might have to upgrade to a newer version of CiscoWorks.
