02-01-2015 01:17 AM
hi,
i've been trying to find a way to generate a report that combines 2 fields:
- IP Address
- Serial Number
and i couldnt find a way to achieve it, i could only find a report that generates either Name&Serial, and i need an IP.
please advise,
thanks!
Solved! Go to Solution.
02-03-2015 04:28 PM
Prime Infrastructure doesn't let you customize its reports much at all.
If you were using Prime LMS you could create a customer inventory report and control what fields are queried and used in the report.
You might be able to extract the information using the PI REST API but that would take at least some basic programming / scripting skills.
02-01-2015 06:54 AM
What product and version number are you asking about?
02-03-2015 06:45 AM
prime infrastructure 2.1
02-03-2015 04:28 PM
