Device support for 1240 Access point
sathappan
I have LMS 2.5.1, and I need to add the 1240 access points to the topolgy map. the access points have snmp configured and the devices are discovered, but the devices are shown as unknown devices in the topology map but not with the wireless access point device package.
is there any workaround for this
with thanks
sathappan.s
sathappan
the Problem was solved when I updated to LMS 2.6
thanks
sathappan.s
AFAIK AP1240 is supported by LMS 2.51
I think you should check the device updates on a regular bases to get the most out of LMS.
Cheers,
Michel
