Try updating the MDF version of the cisco works and then update the Device Pacakges for RME and see how it works.
to Update MDF :
Go to comman services > software center > device update
check the check box for CiscoWorks Common Services and click on check for Update and Update the MDF Pacakges
simialry update the Device Pacakges for RME.
I hope this will help.
Afroj
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
