katerina.dardoufa
Enthusiast
Devices not supported in RME ????
We have two cisco 7201 with the following characteristics:
Cisco 7201 (c7201) processor (revision B) with 917504K/65536K bytes of memory.
Processor board ID 78002382
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
1 slot midplane, Version 2.0
The problem is that these devices seem to be supported in RME 4.1.1, but I am not able to view their logs, get their configuration or anything else related to RME. The configuration is no different from any other router that is fully supported by CW.
What might be the problem?
Thank you in advance,
Katerina
3 REPLIES 3
MICHEL.HEGERAAT
Beginner
Is in RME device list in the "normal" state?
Does it show up in the CDA report?
Cheers,
Michel
Sorry for the question, but how do I generate the CDA report?
Thnx
Hi, everything seems to be ok now. I deleted and re-added the devices.
Thnx for your assistance
Content for Community-Ad
