DFM 3.1.0 on LMS 3.1
lambay2000
Explorer
Explorer
Hi clarke,
Unable to pull devices from DCR CS 3.2.0 to DFM 3.1.0,In process always DFMServer is down and it is showing me 2 instance of DFMServer process i.e example DFMServer & DFMServer1 though when i restart it still get shutdown automatically.attaching the pdshow
Reply waiting for the solution.
29 Replies 29
lambay2000
Explorer
Explorer
Hi clarke
Awaiting for ur reply.
Joe Clarke
This pdshow is truncated. Post the complete pdshow output along with the NMSROOT/objects/smarts/local/logs/DFM.log and DFM1.log.
when i execute a pdshow all outputs goes up in a window.Attached is the file.
there are many files in NMSROOT/objects/smarts/local/logs/ folder for DFM attached many pls refer which u need.
How can i send the full output of pdshow,what adjustment i have to do in command prompt window
You should be redirecting the output of pdshow to a file. For example:
pdshow > pdshow.txt
The problem here appears to be corrupt DFM.rps files. Shutdown Daemon Manager, and remove the DFM.rps and DFM1.rps files under NMSROOT/objects/smarts/local/repos/icf. then restart Daemon Manager.
Joe
After removing those files i stopped and restarted the daemon but still there r no devices in DFM,
Do i have to do some extra job to pull from DCR.
LMS all processes takes 7 to 8 min to come up.
DFM server is still down. Post the new DFM logs.
from which locations clarke can u confirm
The same DFM logs as before. The DFM.log and DFM1.log from NMSROOT/objects/smarts/local/logs.
Attached are the logs for DFM from the above mail location
This is fine. You posted an old pdshow. DFM doesn't automatically manage devices by default. So, go to DFM > Device Management > Device Import, and make sure you have selected devices or groups to manage.
Clarke
Nil devices are present in DFM to import i have cheked by auto as well as manual it says me there no devices to import.
What do you see under DFM > Device Management > Discovery Status?
Please find the screen shots from the DFM
Do you have any devices in DCR? Is this server integrated with ACS?
